order details are not storing in db
Thread begun 2/04/2015 2:34 pm by Kumel | Last modified 2/06/2015 8:23 am by Jason Byrnes | 2573 views | 5 replies |
Kumel
my order details are not stored in db..
was working all fine. don't know what went wrong.
Try a different trigger for your store cart summary and store cart details server behaviors. Instead of "current page submit" try using the Submit_order Button Press trigger.
Some servers block the referrer that is used to determine the "current page" for that particular trigger and it might be what is causing the insert to not take place.
Kumel
i did. its not working still.
Original checkout page is attached. While using original checkout page (ecart checkout) order seems to store.
When same was used in template it doesn't work.
PV msg.
int he store order summary, you have specified a redirect to the order-placed.php page, this is bypassing the store order details behavior.
edit the store order summary behavior and clear the redirect so the store order details behavior can trigger.
Kumel
thanks a lot :)
you're welcome.
