Best approach to image uploading and display?
Thread begun 1/19/2015 5:34 am by Nathon Jones Web Design | Last modified 1/21/2015 9:10 am by Jason Byrnes | 3701 views | 7 replies |
I come across this with many clients...
They want to maintain control over uploading images (products, real estate, portfolio etc) to their websites but they have images in portrait and landscape view. On their websites, however, they want to maintain a uniformed layout so, for example, they might have thumbnails of these images displayed in landscape view on an introductory page of results, leading through to the actual image on a detail page.
Problem is, if they upload a portrait image it shunts the layout all over the place and everything looks disorganised.
Does/can the resize option in the upload behavior, or Image Resizer extension, cope with this scenario?
I understand that there is a "crop from centre" option in Image Resizer but most of our image file names are called from database, in repeat regions, or are tied into a NivoSlider, or something similar, and that usually causes problems (http://www.webassist.com/forums/posts.php?id=35640).
I'm looking for a "once and for all" solution to this because it keeps cropping (ho ho!) up.
I'd appreciate your advice. Thank you.
NJ
There is not a crop option in the upload behavior, but there is a crop option in Image Resizer.
Image Resizer will work fine when using image paths that are called from a database and shown in a repeat region as long as you are using a standard image tag and set the width and height to use, for example:
<img src="path/to/image/<?php echo($row_recordsetName['ColumnName']); ?>" width="200" height="200" />
image resize looks at the width and height settings in the image tag to determine the settings for the resized image.
You'll need to find a different solution for the occasions when you are using the Nivo Slider, there is no "one size fits all" fix for this. you can ask in the Nivo Sliders forums for information on restricting the width and height of the thumbnails, I'm sure the has to be a way in the Nivo Sliders script, but I haven't used it before, so can't really comment.
So I've applied that to an image on the page:
if(TRUE){ // Begin Cached Resized Image: ImageCacheInstance_1421688198741
ob_start();
<img src="property-for-sale/<?php echo($rsProperty->getColumnVal("photo1filename")); ?>" title="<?php echo($rsProperty->getColumnVal("dev_name")); ?>" alt="<?php echo($rsProperty->getColumnVal("dev_name")); ?>" width="400" height="300">
echo(getCachedResizedImageHTML(ob_get_clean(), "property-for-sale/cache", "crop", "", false));
} // End Cached Resized Image: ImageCacheInstance_1421688198741
Does the repeat region sit within the Image Resizer code like this:
ob_start();
while(!$rsProperty->atEnd()) {
$rsProperty->moveNext();
$rsProperty->moveFirst(); //return RS to first record
Or outwith?
Not having any luck with it, in fact my page is ending up blank:
http://www.jb-graham.co.uk/newsite/index.php
Hope you can help. Thank you.
NJ
image resize should be inside the repeat region.
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
Does Image Resizer create a cache version of the images on EVERY view of the page?
That's going to create a HUGE directory of images, and take up a huge amount of web space, isn't it?
no, it does not create a new copy of the image every time the image is viewed, on,y if one does not already exist for the size the page is requesting does it get created.
if you view one page where it is is requesting cropped copy of the image at 200 x 200, it looks to see if that size exists, if yes - it uses the one that has been created, if not - it creates it and uses it.
That's pretty cool.
I've managed to integrate that into a database driven jQuery slider too, which is working well:
Thank you Jason.
NJ
you're welcome.
