HTML Editor is wrapping every line in a div
Thread begun 1/18/2015 6:04 pm by dlovas275157 | Last modified 2/13/2015 11:00 am by Jason Byrnes | 3161 views | 5 replies |
dlovas275157
I have applied the HTML Editor packaged in CSS Form Builder 2.0.1 to my insert and update pages.
When i add content via the wysiwyg textarea, the resulting html has every line wrapped in a div tag (and no p tags or any other html tags anywhere - just div tags wrapping each line).
I looked through all the settings but cannot find anything that would seem to resolve this issue.
dlovas275157
See PM
See PM
dlovas275157
See PM
I could not reproduce on the insert page by typing content into the HTML Editor instance.
on the update page, if i remove the existing content then start typing into the HTML Editor area, it also doesn't use the Div tags.
It seems like you are copying content from word and pasting it in?
For that you need to use the past from word function. I edited the toolbar for the insert and update page to include the source button and also the paste from word button.
when copying content from work, use the paste from word button to clean the word formatting.
Moving forward it would probably be a good idea to upgrade to Data Bridge which uses a newer version of CKEditor. the version you have, FCKEditor 2 has been deprecated for a while now.
