Cannot modify header information
Thread begun 1/12/2015 8:32 am by EPhi86271815 | Last modified 1/29/2015 10:55 am by Jason Byrnes | 2522 views | 7 replies |
EPhi86271815
I am testing the checkout page. It looks like it pulled up the confirm.php page because that is at the top of the page which has an error (see attachment). I am getting that Cannot modify Header information error. I read the other posts and it said something about the ecart code being in the html part of the page instead of in the header. Does this mean that my cursor happened to be on my page when I started the wizard? How does that happen? How do I fix that?
The first error has an expected colon. I will check my code for that.
The wizard created these pages. I noticed that it only created 4 pages this time. It did not create the "pp_..." pages, though I did not deselect them in the wizard. What makes them get created or not get created? The wizard determined I didn't need them?
Thank you!
in this case, the headers already sent error is happening because of the first error.
the first error is the header that has already been sent.
so to fix it, you will need to fix the first error. if you need help with that, send a copy of the cart object and the eCart_definition files in the WA_eCart folder.
as for the pages that are created, the pp.... pages that you mention are created only if you select to use PayPal Express checkout as the gateway. if you use a different gateway, and deselect the option to include Express checkout, the pp... pages are not needed, so not created.
EPhi86271815
See private message.
EPhi86271815
see private message
the error was in the shipping server behavior on the conform page.
i changed line:
212:
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageWeight"] = "".$mdacCart->DisplayInfo("") ."";
to specify the total weight column:
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageWeight"] = "".$mdacCart->DisplayInfo("TotalWeight") ."";
EPhi86271815
see private message
you're welcome.
