Undefined index: WAVT_confirmcart_Errors in
Thread begun 1/07/2015 4:31 pm by rgolfer | Last modified 1/09/2015 1:07 pm by rgolfer | 5676 views | 9 replies |
rgolfer
Hi Jason,
I'm having an error message when I go through the checkout procedure.
The full error is ...
Notice: Undefined index: WAVT_confirmcart_Errors in C:\wamp\www\toyo_dev\Tdisplay\Tconfirm_cart.php on line 196
This is the code in that page ...
<?php if ((isset($_POST["CheckoutWizard_submit"]) || isset($_POST["CheckoutWizard_submit_x"])) && $_SESSION['WAVT_confirmcart_Errors']=="" && !isset($_POST["forShipping"])) { ?>
I was first getting an error stating cannot find /webassist/framework/ajax_wrapper.php
I found the file from another site I built and added this file in. It got me a little farther but now this message comes up. (see error_cart.jpg)
Funny thing is I can hit the "submit" button and it posts the order. It does not however allow an email to be sent.
Any ideas on this one?
try changing that code to:
<?php if ((isset($_POST["CheckoutWizard_submit"]) || isset($_POST["CheckoutWizard_submit_x"])) && $_SESSION['WAVT_Tconfirmcart_Errors']=="" && !isset($_POST["forShipping"])) { ?>
yes, that code would go in the wauve_Tconfirm_1.php page.
the format for setting a cc and BCC address is not the same however.
for a CC address, it is no longer:
$CCVal ="name@domain.com";
it is now:
$WA_MailObject = WAUE_AddCC($WA_MailObject,"name@domain.com");
for a BCC address:
$WA_MailObject = WAUE_AddBCC($WA_MailObject,"name@domain.com");
so you will need to edit your code accordingly.
rgolfer
Thanks, it works now but I'm not getting the emails to go through. I'll have to double check my email settings to make sure I haven't changed something.
I'll make sure I get that working first before attempting the re-direction by location.
rgolfer
Still can't get email to work
Hi Jason,
I verified all email settings were correct and verified that the double opt in registration is working properly with emails etc.
But the problem is with cart email. The orders are going through OK and everything is posting to the database. There are no payment options, shipping or even taxes, This gets done at another level. Only thing that is missing is the email verification. This is not going to the customer or to the CC emails. Is there a name issue again like above, or something else? I've checked with the service provider (out IT dept) and they say everything should be working.
Hoping you could help me through this last part?
Any ideas?
on the confirm page, the store order details behavior is set to redirect to the success page.
this happens before the email can be sent.
change line 93:
$WA_redirectURL = "Tcheckout_success.php";
$WA_redirectURL = "";
rgolfer
That did it Jason. Thanks!
you're welcome.
rgolfer
Hi Jason,
Could you do a quick check on the redirection of the emails going to different provinces? I have made the changes and the email goes to the customer but not the CCd staff.
Please see PM
where this is custom coding, you should sign up for a premiere support appointment for help with this:
http://www.webassist.com/premier_request.php
rgolfer
I guess it does fall outside of the norm doesn't it. I forgot we went through that process last time. Thanks for your help.
