Problems Using 'Security Assist / Show region
Thread begun 12/18/2014 7:38 am by s.joiner74419001 | Last modified 12/19/2014 8:18 am by Jason Byrnes | 2071 views | 3 replies |
s.joiner74419001
I am wanting to use the 'show region' behaviour to show Table Data / hide 'Table empty message'. The Data in the table is using a recordset that is filtered by a session variable so it only shows the records of the person logged in. The table of data is enquiries made by the user/member/person logged in. I have a message above the table saying "You do not currently have any active enquiries" which I want showing, only if there is no records/enquiries in the database. I also want the table that displays the data to be hidden if there is no records/enquiries in the database.
I have tried all sorts of combinations with the access rules but I just can't get this to work!
Any pointers please!
Use the Show If Recordset Is Not Empty / Show If Recordset Is Empty behaviors for this, not the security assist show region behavior.
s.joiner74419001
That'll be the one!! Cheers Jason!!
you're welcome.
