eCart 6 not storing orders or order details into database
Thread begun 12/10/2014 6:00 pm by simmo515303621 | Last modified 12/19/2014 9:21 am by Jason Byrnes | 2788 views | 4 replies |
simmo515303621
Hi Guys,
I am using eCart 6 and Dreamweaver CC
I have everything implemented ok as far as I can see, I get to the checkout_success.php but no orders or order details are being stored in the database. I am using the database recommended ( sample database )
I am not currently using a Payment Gateway as the system I am building is for quoting only.
Here is a link to check http://www.popup.internetsavvy.com.au/details.php?product_id=3 just add the product and try to check out. If you do this twice you will notice that the order numbers stays the same "1" as there are no details being stored.
simmo515303621
Done.
simmo515303621
Hi Jason,
Sorry it has been about a week, and I have not heard back from you..
Any word please?
Looks like in the Data Base, the OrderShipAddress column is set to not allow Null, and that is causing the insert to fail. you will need to update the order table and change that column to allow null values.
