Broken update page
Thread begun 12/09/2014 10:45 am by iain331081 | Last modified 12/09/2014 11:45 am by Jason Byrnes | 2742 views | 5 replies |
iain331081
Broken update page
Not sure what I've broken here - I had a bit of trouble getting my dynamic dropdowns to work. They are now, and populating with the correct values on the update page. But the update isn't working. I'm sure it must be something simple, but I can't see it for looking as I've been working on this for a while.
I have attached the page below - if someone could have a look that would be much appreciated. Hopefully a simple one!
Thanks.
following your instructions, i get to this page:
lodge_keyword_update/index.php?ActivityID=92
the code on this page does not match the code you attached in your message.
On the server, the problem is the trigger for the update behavior is set to use a button named update, but the button on the page is name insert.
iain331081
Thanks Jason - the View Lodge Keywords and Categories 2 link should get you to lodge_keyword_update_2
In that one the update behaviour and button are both named update.
the first time around that link dod not exist for me, perhaps in the future a direct link to the page would be better?
anyway,, the hidden field used to pass the ID of the record to update was missing from the page:
<input type="hidden" name="WADAUpdateRecordID" id="WADAUpdateRecordID" value="<?php echo((isset($_GET["invalid"])?ValidatedField("lodgesupdate","WADAUpdateRecordID"):$_GET["ActivityID"])); ?>" />
iain331081
Thanks Jason - all fixed.
you're welcome.
