Sort Column error
Thread begun 8/26/2009 5:12 pm by 4egidio363291 | Last modified 11/17/2009 10:46 am by Jason Byrnes | 3923 views | 5 replies |
4egidio363291
Sort Column error
I am sorting columns using Datassist sort server behavior. I am able to get some columns to sort but others I'm getting the error.
Column 'UserZip' in order clause is ambiguous.
I attached the page with the problems. FYI, the columns that work are Title and List Price. City, State and Zip are returning this error.
Please advise. thank you
This error means there is a column named UserZip in more than 1 of the table being used in your query.
You query is returning column from the Orders, OrderDetails and Users tables. You need to specify in your link which table the userZip column to use is in. For example, to use the userZip column in the users table, your link should look like:
<a href="buynintendodsgames.php?sort=Users.UserZip">Zip</a>
4egidio363291
Sort
Thanks Jason that works.
One last thing, is there image that is suppose to show up next to the sort column to show its sortable? Like a upside down triangle or something?
No, the sort server behavior will not do that for you, you would need to add the image yourself.
rob294118
Clickable Columns
I was able to create the sort columns but there is nothing to click on to sort. Shouldn't there be a link?
Thanks.
You have to create the link.
See the "Sorting by column links" tutorial in the solution recipe section of the DataAssist support page:
dataassist/
