Combine multiple databases in a parent database
Thread began 11/28/2014 6:58 am by Erin | Last modified 12/02/2014 10:58 am by Jason Byrnes | 639 views | 3 replies |
Erin
Hello, I am searching for the easiest way to take multiple databases and have them appear in a single parent database, including updated information after the individual databases are updated. Is there an easy way to do this? For a bit more context, all of the databases have the exact same structure and wouldn't need to have any alterations. I thought there might be a way to do this within MySQL itself. If not, I also have used DataAssist to create results and update pages for each of the individual databases, so perhaps it is easiest to update my code on the update page?
Thanks for any assistance!
No, there is not an easy way to combine databases.
You would need to create queries to return data from each database table.
Using Data Assist, you would need to create a separate set of pages for each database.
Erin
Okay, thank you for the response. Just to clarify, I have created a separate set of pages for each table (all within same database), and I just want to find a way to view all of these entries on one page. So, is there any way to have the updates occur simultaneously in original table and a new table? Or would I be better off developing a page that displays multiple tables?
The wizard won't create pages that manage multiple tables at the same time, if you like, you can create the pages your self creating the necessary recordset, forms, and adding the nasally update behaviors, but there is not an automated way to create this.
