CSS Menu Writer xml file problem
Thread begun 11/14/2014 3:21 pm by jurinski334466 | Last modified 11/21/2014 1:43 pm by Jason Byrnes | 1879 views | 4 replies |
jurinski334466
CSS Menu Writer is giving me this error: "There was an error loading some of the xml files needed to generate the page." and I cannot edit or enter the interface to create or edit the menus.
I am using Design Extender 1.2.0, but this occurred on 1.1.9 as well. Since the current menus worked I did not deal with the problem for the past month, but now I need to create and update new menus.
I have installed and reinstalled Design Extender and the rest of the Super Suite extensions (latest versions), made new configuration folders, deleted the MacFileCache, and deleted presets multiple times in various order and nothing changes. I get the same error message every time I open CSS Menu Writer. The extensions seems to retain the menu contents information, but not the theme which was last built off of an Accent theme. It also does not work if I try to use a different site in Dreamweaver. I am running Dreamweaver CS6 on a Mac running 10.6.8. I've done something, but I don't know how to fix whatever it is I did. Can you help me get this fixed? Please let me know if you need more information. Thank you!
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
jurinski334466
Thank you!
Hi, Thank you that would be great! Please see PM for info to set up a time.
I will call tomorrow to take a look at this.
I have forwarded your information to Ray and asked him to have a look at the problem.
