Sessions not being killed off
Thread begun 10/22/2014 5:05 am by mrs | Last modified 10/23/2014 8:52 am by Jason Byrnes | 965 views | 3 replies |
mrs
I've created a few sessions on a details page that I am using to populate content on a results page that is filtered based on the session info. However, when I move from one detail page to another, I am finding that the sessions are not being killed off and repopulated with the new session info leading to inaccurate content being displayed. If I refresh the page, then the correct info is displayed. Why?
I'm using sessions to enable me to relate content from one table to another. So, my news table is giving me the key ID of an article (articleID), that articleID is then related to an images table where the filtering is applied and displayed on the detail page. It's here that the wrong content is being displayed until the page is refreshed.
What have I done wrong? Pages in question are attached. Detail page is the session initiating page.
Thanks.
Mat
order of operations.
you have 2 recordset, the first:
WADAtbl_news
is at lines 70 - 78 and uses the fld_id url variable for the filter.
the second:
rs_images
is at lines 80 - 88 and use the articleID session tho filter.
However, the code to set the articleID session is after the recordset at lines 122 - 125
This means that the value in the session is not changed till after the recordset that uses it is created, ergo, the recordset is created using the old value.
move the code to set the session so that it comes after the first recordset and before the second.
mrs
Aha! Perfick! A silly error really.
Thanks Jason.
You're welcome.
