javascript errors unexpected behaviors.
Thread begun 10/15/2014 10:07 pm by gzirfas374932 | Last modified 10/16/2014 10:35 am by Jason Byrnes | 997 views | 1 replies |
gzirfas374932
while executing onResize ....refreshUI is not defined......
I get three errors after installing mysqli server behaviors. (screen caps attached).
Do I still need to have the Deprecated Panel Support extension enabled? When I turn it off my server behaviors don't work and my database palette has nothing in it so I assume I still need it. (Dreamweaver CC)
In the define recordset it won't let me put in the recordset name until ALL the other information has been filled in, then I can name the record set.
I get other multiple javascript errors. They are also attached.
I need some help here.
Thanks!
Are my attachments coming thru, I don't see them anywhere
Yes, you still need the deprecated server behaviors.
for the errors:
reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
the attachment system is currently broken, we will have it fixed later this afternoon.
