Dreamweaver CS4 crashing when using CSS Form Builder
Thread begun 10/01/2014 6:30 am by kristyway385888 | Last modified 10/10/2014 9:07 am by Jason Byrnes | 4163 views | 7 replies |
kristyway385888
Hello. Hoping you can assist. I have read through related messages for help, and after trying a few things, I still have my Dreamweaver crash when customising fields on a new form. CSS Form Builder just locks up and says (Not Responding).
Problem first started whilst I was using version 2.0.0. I would get as far as clicking the 'Edit' button from the Form Contents screen, and it would lock up. I discovered a new version, so uninstalled the earlier version, and installed the newer version. Software appeared to run a bit quicker and I was able to add and delete fields, so I thought the issue was resolved.
I don't even get as far as finishing the form before it no longer responds. I can pre-select a form, and edit the fields and go back to the Form Content screen, but if I try to re-enter the Edit button or Finish the form, it stalls, and says (Not Responding).
I have cleared the .dat file, closed and restarted Dreamweaver, created a new php page, closed down the majority of my programs to free up memory. I don't know what is wrong. I have relooked at the 'common problems' page and done its suggestions. Problem is still occurring.
Something strange is happening also, the form I saved as a single preset, the preview has applied this design into every preset form, and all the form designs look the same. This is a mess.
It has been a while since I have used CSS Form Builder, but on last time, I haven't had this issue.
I use Dreamweaver CS4. Windows 7 PC.
CSS Form Builder 2.0.1, this is the only Webassist extension I have installed.
I'm really you can help.
recreate the users configuration folder as outlined in step 12 of the Adobe troubleshooting guide:
http://helpx.adobe.com/dreamweaver/kb/troubleshoot-javascript-errors-dreamweaver-cs4.html#main_user_config
then uninstall all extensions from the extension manager, then reinstall form builder:
kristyway385888
Hi Jason, thanks for that. I did the Dreamweaver CS4 regedit reset. I was hopeful.
Went to create a new form, got as far as selecting the drop down of 'Registration' template, and it's locked up again.
Disheartening... now i really don't know what else to do.
kristyway385888
Hi. I've been trying the forms again, and I've had more success without it locking up. I've disabled the automatic preview and I think this has helped.
So I've managed to implement a form into my .php page. I then go to create a email message. Now I hit Javascript errors.
First one that pops up is relating to WAUEInsp.html (have attached a screen shot). This repeats 4 times.
Second one that pops is a validation rule error. I have not changed any code of the form, and the name is still is a required field, but I get an error relating to this now. On either clicking yes or no, my php page is completely ruined with all formatting disappearing, and it looks like a mess.
I've shutdown Dreamweaver, deleted the WinfileCache.dat file, and restarted. I get another javascript error saying wa not defined...
Pleeeease help! I appreciate your time.
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
kristyway385888
have sent you a private message for time proposed
kristyway385888
Hi. just checking to see that the time proposed is scheduled in... I'll be making this time specifically available for the skype call, so if you can confirm that the day/time works for your engineers, I'll be ready. Thanks very much.
Yes, Friday at 3pm EST will be fine.
