How to make Power CMS install...
Thread begun 8/25/2014 9:28 am by Steve | Last modified 8/25/2014 10:15 am by Jason Byrnes | 1710 views | 3 replies |
Steve
Sounds simple huh?
I usually have to manually upload all files, manually create the tables, etc etc which takes a long time.
Somewhere in this extension is the means to automatically create the base Admin files but the event never fires.
Initially I create a blank DB and a simple recordset in an attempt to start the process.
Then using the Insert Into CMS feature it trys to achieve some goal but repeatedly fails with the error saying that there are insufficient privileges to create tables. But that is not true as I have given more privileges than I would prefer. Also as a test I can create a new table using the same credentials:
<?php // Connects to your Database mysql_connect("your.hostaddress.com", "username", "password") or die(mysql_error()); mysql_select_db("Database_Name") or die(mysql_error()); mysql_query("CREATE TABLE tablename ( name VARCHAR(30), age INT, car VARCHAR(30))");
Print "Your table has been created"; ?>
No problem, table created...
I remember going through the same headaches last time with no resolution than uploading another sites Admin files and creating / populating all the DB tables manually.
Any idea or tips that could make this more painless?
the error saying that there are insufficient privileges to create tables usually happens a s a result of a problem in the site settings for the testing server.
It is almost always a problem with the webURL and the root directory settings.
make sure that the Web URL is a valid URL for the testing server.
In some cases when using a remote FTP connection to the server, you may need to set the root directory to point to /httpdocs or another folder to get the http site root on the server.
double check the testing server settings for the site definition.
Steve
Perfect! Testing server was the issue as we were running a temp duplicate site until we updated the proper domain name to our server.
As always, Thanks Jason for excellent tech support!!!
you're welcome.
