field contents makes page not show
Thread begun 8/18/2014 7:30 am by Sweens | Last modified 8/18/2014 10:37 am by Sweens | 1867 views | 2 replies |
Sweens
Hi Jason
This extension is brilliant!
On page http://www.rotary-ribi.org/districts/tab-clubsmap.php?DistrictNo=1180 I have managed to get different colours for different days, but there are another couple of refinements I'd like to add;
1) to NOT have a default (last record) details displayed when the page opens.
2) In the following code on page wagmp_map_2.php, I'd like to make 2 additions;
a) There is a 'MeetVenue' field, which contains a few lines of text. Whenever I add clubs.MeetVenue as a field, the entire map fails to load - I assume this is because of the field contents. I have tried to add ".nl2br($row_rsClubsCoOrd['MeetVenue']) ."<br /> into the code below, but the map then doesn't display.
b) have an if statement in the code, so if there is a cluburl in the recordset, it displays a link to their website
infowindowtext: '<span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;"><?php echo str_replace("'", "\'", "<strong>".$row_rsClubsCoOrd['ClubName'] ."<br />Meet on:</strong> ".$row_rsClubsCoOrd['DayName'] ."<br />".$row_rsClubsCoOrd['MeetPostCode'] ."<br /><strong>meeting coordinates:</strong><br />(".$row_rsClubsCoOrd['LAT_Pos'] .", ".$row_rsClubsCoOrd['LONG_pos'] .")"); ?></span>',
full: '<?php echo str_replace("'", "\'", "".$row_rsClubsCoOrd['LAT_Pos'] .""); ?>,<?php echo str_replace("'", "\'", "".$row_rsClubsCoOrd['LONG_pos'] .""); ?>',
addressType: 'coordinates',
3) - sorry, just remembered this one; I've experimented with the different map display areas (small country, reasonable driving distance, neighbourhood etc), but can' find one that will just cover all the place markers. Is this possible?
Hope you can help
Cheers
Chris
you have another thread where I am going to call to look into the problem:
http://www.webassist.com/forums/posts.php?pid=178760
I Will look at this one at the same time.
Sweens
Thanks Jason
