Double opt in email Verification Code line coming in multiples - error with user verify page.
Thread begun 8/07/2014 3:41 pm by rgolab68503 | Last modified 8/08/2014 11:29 am by Jason Byrnes | 2498 views | 3 replies |
rgolab68503
Hi Jason.
ot past the email problem but now as I receive the emails it is received with multiples of the same Verification Code.
Please verify you're an actual person by clicking on the link below.
Form Submitted: 8-7-2014 | 10:35 PM UTC
Verification code: Click here to verify your email address.
Then when i click on the any of the links i get the same error from any of the links pressed.
( ! ) Notice: Undefined variable: totalRows_rsVerify in C:\wamp\www\toyo_dev\login\user-confirm.php on line 4
Call Stack
# Time Memory Function Location
1 0.0025 448088 {main}( ) ..\user-confirm.php:0
Unknown column 'users.randomString' in 'where clause'
Line 4 caries the session start code:
@session_start();
if(!($totalRows_rsVerify == 0)) {
$_SESSION["emailVerified"] = "1";
i have gone through the tutorial several times to make sure everything is set properly and in my thinking everything is correct.It originally looked like it was seeing the randomString column in the database but I triple checked that the spelling is consistent and it definitely is in the database and the registration process does write to it.
Any ideas?
in the blank templatefile, ther eis a code block to loop through the form elements, you have the link is this loop.
change:
foreach( $_POST as $pkey => $pval ){
if (!RemoveValue($pkey,$remove,$removeBegins,$removeEnds,$removeIncludes)) {
if (get_magic_quotes_gpc()) $pval = stripslashes((is_array($pval)?implode(", ",$pval):$pval));
<tr valign="top">
<th style="font-size: 12px; width: 134px; text-align: right; padding: 3px 10px 3px 3px; font-weight: bold;">Verification code:</th>
<td style="font-size: 12px; padding: 3px;"><a href="http://dev.toyosupport.ca/login/user-confirm.php?id=<?php echo $_SESSION['SecurityAssist_IDemail']; ?>&randomString=<?php echo $_SESSION['rpw']; ?>&email=<?php echo((isset($_POST["Registration_group_5_Email_Address"]))?$_POST["Registration_group_5_Email_Address"]:"") ?>">Click here to verify your email address.</a></td>
</tr>
<tr valign="top">
<th style="font-size: 12px; width: 134px; text-align: right; padding: 3px 10px 3px 3px; font-weight: bold;">&nbsp;</th>
<td style="font-size: 12px; padding: 3px;">&nbsp;</td>
</tr>
<tr valign="top">
</tr>
<tr valign="top">
</tr>
on the user-confirm page, the code to set the session comes before the code for the recordset.
the recordset code ends at line 59, the session code needs to come after that.
rgolab68503
Thanks Jason
The email now shows one link.
I was still getting a "Unknown column 'users.randomString' in 'where clause'" when I click the link and it goes to the user-confirm.php page.
Totally my fault!! You can see below I simply copied the text from the tutorial forgetting that MY users database is not called "users" but "entry". Below I use users.randomString <> '0' in the where clause rather than what it should be entry.randomString <> '0'
SELECT *
FROM entry
WHERE ID = colname AND entry.randomString = paramrandomString AND entry.EmailAddress = paramemail AND users.randomString <> '0'
"Double opt in" works great now.
glad to hear it's working.
