Dataassist help regarding displaying PDF files.
Thread begun 6/17/2014 6:09 am by Kumel | Last modified 6/17/2014 11:26 am by Jason Byrnes | 4945 views | 10 replies |
Kumel
1- I have a registration page where a user registers & then all his details are shown in home page.
2- I have created a page where admin can upload pdf files into a folder & this is stored in data base (its linked with userid of user to whom it is needed).
entries are: userid (to whom it is) , fileid( pdf file) , & filename ( name of pdf file) thats all.
now- i want to show these data for those users which the admin had uploaded for that particular user. I hope you are getting my point.
Please tell me how can this be done.
Ex:
Lets says admin uploads file named: 123.pdf & 234.pdf for user name: XYZ
So when XYZ logins, all files linked to his id must be shown. With PDF name & file to view or download.
I hope you can help me out with it.
I have created two different database: 1st is PCMS2_USER(all details about user when he registers) & 2nd is PCMS2_USERFILES (which has userid linking to that of user, fileid, & filename) thats all.
Regards
Kumel
wel i have got this done myself.
So can you tell me how a admin can see list of files been uploaded for all? & then make it deleted by admin?
Use Data Assist to create a results and delete page set for the table that contains the file names.
Kumel
wel that was nice :) ok now i have only 3 columns in 1 is UserId FileID & Filename.
Now i want user name to be shown linked with UserID, which is from other table. How do i do that?
use a join query:
http://www.w3schools.com/sql/sql_join.asp
Kumel
Well i got that, this is what i got:
SELECT pcms2_userfiles.userid, pcms2_users.UserCompanyName
FROM pcms2_userfiles
INNER JOIN pcms2_users
ON pcms2_userfiles.userid=pcms2_users.UserID
But results aren't showing up properly.
Results are just showing that of one customer. (name)
please find attached DB.
use a repeat region on the results page to loop through the entire recordset.
if you need help in setting this up, we can help through a premiere support appointment:
http://www.webassist.com/premier_request.php
Kumel
I have used repeat region. still it ain't showing other results.
Kumel
I don't understand why i need to pay for the service. I thought the service is free of cost. But here i can see that few of my problems will not get solved until i pay extra for it.
I m sure the problem which i m facing is very simple & can be solved easily. But i m not a coder. so.
