Framework Builder Themes
Thread begun 6/14/2014 9:20 am by Webbie | Last modified 6/16/2014 10:25 am by Jason Byrnes | 2168 views | 3 replies |
Webbie
My theme question is: i set up a site with PowerCMS and have allot of pages and not exactly sure if all of the page links are working like they should be. I am wondering if this would be a good time for turning my template into a theme?
The thing i am worried about is i only have one template which is the home page and all the rest of the content pages are different then the home but same to their own, if i create a theme and applied it to all of my pages will the theme automatically just make it look identical as the home page? How do you assign what content to leave out of the theme template?
Does starting a theme throw powerCMS off in any way? I want to be careful because my CMS is working so great right now i don't want to ruin this streak of good luck.
A theme is derived from a template.
So if you converted the home page template to a theme and applied that theme to the other pages, then yes, your other pages would use the same design as the home page.
a Theme is only need to be used on pages where you want to apply a consistent design.
The content that is unique to the p[ages is defined in editable regions.
When you create a template, you add editable regions to it. whatever is no in the editable regions is applied to the page as the design. on each page, you add the unique content into the editable regions.
Webbie
reply
so i can set up more than one theme and add the pages manually?
Yes, that is correct.
