User Update country field not working
Thread begun 6/10/2014 6:09 pm by johna1964 | Last modified 6/11/2014 10:36 am by Jason Byrnes | 4089 views | 9 replies |
johna1964
Hi! I am seeking help with one form field on the User Update page. I have found the is no closing spry validation code and this or something similar should be within the page:
var User_Update_group_11_Country = new Spry.Widget.ValidationSelect("User_Update_group_11_Country", "none", {validateOn:["blur"]});
When I attempt to add it manually, the Spry Select properties tell me the spry structure appears to be damaged. Can you take a look at it with and without the code? Maybe you can see what is missing.
It will not allow anyone out of the country US to update correctly. It is automatically selecting United States and won't allow any change.
You wont be able to add that spry validation manually, a spry validation field requires more than just the that one line of code.
to add spry validation to an existing select field, select it in design view, then go to:
insert -> Spry -> Spry validation Select
johna1964
Hi Jason,
Got it. Thank you
Now, I need to know what to put in the dynamic list menu dialog box fields. These are set now to the following:
Options from record set: None
Values:
Labels:
Set Value Equal to: <?php (isset($_GET["invalid"])?ValidatedField("userupdate","User_Update_group_11_Country"):"") ?>
Are these correct or do I need to change something? I have uploaded the updated file.
Thank you for your help!
That looks correct.
johna1964
Hi again,
The reason I am asking is because all of the other form fields have for example:
<input id="User_Update_group_1_Phone" name="User_Update_group_1_Phone" type="text" value="<?php echo $row_SecurityAssistusers["UserPhone"]; ?>" class="formTextfield_Large" tabindex="12" onblur="hideServerError('User_Update_group_1_Phone_ServerError');" />
And so it looks a bit different.
I will upload and test.
Thank you!
ok, so really what you are asking is how to use the recordset value on page load and the validated entries value on validation field.
the code for that would be:
<?php (isset($_GET["invalid"])?ValidatedField("userupdate","User_Update_group_11_Country"):$row_SecurityAssistusers["UserCountry"]) ?>
johna1964
Hi Jason,
Apparently. :-)
When I open the dialog box, the options for the record set section are none; Security Assistusers; and, SecurityAssistusers. Do I use either one of the options or do I use specifically the first or second? I think this has to do with the double opt in registration.
Thank you much!
dont use any of the recordset settings.
for the select value equal to option, use the code i provided previously:
johna1964
Thank you Jason :-)
you're welcome.
