won't lt me add new form
Thread begun 6/10/2014 10:11 am by jean395771 | Last modified 6/10/2014 1:03 pm by Jason Byrnes | 2032 views | 3 replies |
jean395771
I installed the new databridge for dreamweaverCC. The menu shows adding new form, but it just flashes and doesn't show the options or any code for a new form.
After installing Data Bridge in the extension manager, when you open DW it should launch the WebAssist installer. It sounds like the WebAssist installer did not run.
try:
-Close DW
-In the extension manager, uninstall Data Bridge, then install it again.
-Open DW, the WebAssist installer should run, if not, open a php page to force it to start. Once the WA installer completes, make sure to restart DW.
jean395771
Thank you
Thank you. That worked.
Glad to hear it is working.
