does Image Resizer work with base64 images
Thread begun 6/05/2014 5:47 am by asarcona308398 | Last modified 6/05/2014 9:20 am by Jason Byrnes | 2958 views | 3 replies |
asarcona308398
Hey Guys,
I'm trying to use ajax to update a photo on a page and the base64 image dynamically generated does not seem to re-size even though the image properties give the correct dimensions...
Here is the excerpt:
<input type="file" name="inst_image" id="inst_image" style="background-color:#FFF" onchange="PreviewImage()" />
function PreviewImage() {
var oFReader = new FileReader();
oFReader.readAsDataURL(document.getElementById("inst_image").files[0]);
oFReader.onload = function (oFREvent) {
document.getElementById("uploadPreview").src = oFREvent.target.result;
</script>
if(TRUE){ // Begin Cached Resized Image: ImageCacheInstance_1401971755331
ob_start();
<img width="176" height="176" id="uploadPreview" title="New Class Image" />
echo(getCachedResizedImageHTML(ob_get_clean(), "images", "proportion", "", false));
} // End Cached Resized Image: ImageCacheInstance_1401971755331
I am uploading the file ok on update, but the image displayed on screen is skewed.
Also the image properties show....
data:image/jpeg;base64,/9j/4AAQSkZJRgABAgEAYABgAAD/7gAOQWRvYmUAZAAAAAAB...
instead of the extensions folders to the resized image.
I hope you guys have a way to use the extension in this type of application... or would consider including this in future release
Let me know
Tony
Image resizer wont work with javascript generated images.
it will not resize the image that is dynamically added to the page through the ajax script, it can only resize images that are part of the img src at page load.
asarcona308398
OK thanks,
Tony
you're welcome.
