How to hide an empty repeat region upon the display of a show if region
Thread begun 6/02/2014 7:46 pm by mora398588 | Last modified 6/04/2014 7:48 am by Jason Byrnes | 1880 views | 3 replies |
mora398588
I would like the repeat region (if it returns empty) to be replaced or hidden upon the display of the show if region.
I have created a security assist rule which returns the show if behavior through the use of an URL Variable (i.e., blog_categories.php?CatID=13&updated=true)
Well, the variable is working and the show region displays correctly. However, the empty repeat region displays with sections showing no data where dynamic data used to be. I am uncertain if I must create a new security assist rule which hides the repeat region if empty or make any further modifications to existing rules or code.
I have attached my file for your review, if needed. Thank you for your time.
Select the repeat region, then in the server behaviors panel, click the plus button and select
show if -> Recordset is not empty
that will show the repeat region only if a result is returned in the recordset.
mora398588
Thank you, Jason.
That was very simple.
you're welcome.
