CSS menu writer is causing my pages to not load and now show the menu
Thread begun 5/27/2014 7:29 am by roby258376 | Last modified 5/27/2014 9:30 am by Jason Byrnes | 4739 views | 9 replies |
roby258376
I am using CSS Menu Writer in DW CC. When I add a menu, the page no longer loads browser, it cuts off just before code calling menu is invoked
The screenshots below are of the page in the browser, showing no menu info and cutting off the content and footer. And the page as it shows in DW CC, complete with menu, content and footer areas.
CraigRBeta Tester
I am guessing you have a missing file or path error on your page
try adding the following to line 1 of your page to help troubleshoot...
error_reporting
(E_ALL);
roby258376
Parse error: syntax error, unexpected T_STRING, expecting T_OLD_FUNCTION or T_FUNCTION or T_VAR or '}' in /hsphere/local/home/robinwww/thoroughwebdesign.com/master/webassist/framework/framework.php on line 3
is the error I get.
CraigRBeta Tester
not come across this one before, but now you have an error, it will be easier to diagnose.
this thread may help,
http://www.webassist.com/forums/posts.php?id=19490
otherwise Jason from WA will have to step in
What version of PHP is being run on the server?
Design Extender / Menu Writer requires PHP 5.2 or greater. The error you are getting suggests that your server is running an earlier version of PHP
roby258376
5.2.9
roby258376
private message is below, won't let me submit without typing in this field too
roby258376
See private message
phpinfo() shows the server is running PHP 4.4.9:
See PM
