SA2 with encrypted pass changes to non-required field so update-user deletes pass if user doesn't enter it.
Thread begun 5/22/2014 9:45 pm by RMar93560704 | Last modified 5/25/2014 3:24 am by RMar93560704 | 2088 views | 4 replies |
RMar93560704
Using the wizard, the password and confirm p/w field are set to required fields if non-encrypted - but if I change to any encryption, they become non-required, so on the generated update user page, if the user bypasses those fields (if they're not changing that info), the password in the database is deleted. Do I manually have to make those required fields after the fact, and if so, how?
Thanks in advance, Jason.
Send a copy of your update user page please.
RMar93560704
Attached below - it's boilerplate from the Wizard, but then placed into a template/framework. But it's in the wizard that this happens - you can't have the password be a required field if you choose to encrypt it there.
Here is an updated copy of the page.
The password is not required, but it shouldn't delete the password if none is entered anymore.
RMar93560704
Thanks, Jason, I'll give it a shot!
