eCart Store Summary only partially inserted into Database
Thread begun 4/21/2014 3:44 pm by joerg431091 | Last modified 4/22/2014 12:39 pm by Jason Byrnes | 3121 views | 5 replies |
joerg431091
I upgraded to eCart 6 and added the Checkout process to a store for the first time. I am having trouble inserting the eCart Store summary into my existing database.
I hope I explain the problem correctly since I am a little confused and can not figure out what I am missing:
When I tried it first only some of the columns had been uploaded to the database so I checked in the “Store Cart Summary in Database” Server behavior and noticed that only those values had bindings to the columns. So I simply did bind the missing values to the columns using the server behavior in the confirm.php page.
But the values are still not included in the Database. I must miss something. Did I do this correctly by only add the values in the server behavior and upload the confirm.php page or is there something else I need to do?
Thanks a lot.
Joerg
Can you provide a little more details please.
What columns in the orders table are not getting a value?
also please include a copy of the page so I can see the code.
joerg431091
Hi Jason,
Thanks a lot for your response. I will attach a copy of the confirm.php page to this post.
I guess it must have to be something with the Database column names. The database is based on the Webassist database and most columns had been renamed over time. The column names that are still the same such as OrderEmail or OrderShipAddress for example are uploaded correctly but the columns that have been changed in the past (OrderBillFirstName, etc) are not uploaded.
So I guess it has to do with the binding of the values to this columns.
We have other stores (eCart 5) that work perfect with the new names and we simply changed the values in the server behavior of the confirm.php page for those stores. So I thought it is going to be the same with eCart 6 (adjusting the server behavior values) but I must miss something.
Here are the columns that are correctly uploaded to and the once that are not:
Correctly included are:
- all orderdetails information
- OrderAmount
- OrderShipName
- OrderShipAddress
- OrderEmail
- OrderTax
Not uploaded are:
- OrderBillFirstName
- OrderBillLastName
- OrderBillCompany
- OrderBillName
- OrderBillAddress
- OrderBillAddress2
- OrderBillCity
- OrderBillState
- OrderBillZip
- OrderBillCountry
- OrderBillEmail
- OrderBillPhone
- OrderShipAddress2
- OrderShipCity
- OrderShipState
- OrderShipZip
- OrderShipCountry
- OrderShipPhone
So what I did so far was going to the "Store Cart Summary in Database" server behavior of the confirm.php page and assigned the values to the columns.
Thanks a lot I appreciate your help.
Best,
Joerg
the code for the oder email binding (which you say is working) uses the CheckoutWizard_Basic_Default form:
WA_getSavedFormValue("CheckoutWizard_Basic_Default","Email_Address")
The code for the OrderBillFirstName is using a diferant form, CheckoutWizard_NewFromBlank_Default,:
WA_getSavedFormValue("CheckoutWizard_NewFromBlank_Default","First_Name"))
go through each of the bindings and make sure they are all using the same form binding, CheckoutWizard_Basic_Default
joerg431091
Oh my god you are right. Thank you so much!!!!!
I changed the checkout form design from Blank_Default to Basic_Default at one time and did not know that the old would still show up somewhere.
That of course did take care of it.
Thanks as always and have a great day.
Best,
Joerg
you're welcome.
