Manage Relational Data on Update Pages
Thread begun 4/21/2014 12:57 pm by jake269602 | Last modified 4/24/2014 7:57 am by Jason Byrnes | 1650 views | 3 replies |
jake269602
I'm unable to get Relational Data to work on update pages. I'm using Check boxes, and I can check them and save, but when I go back to update the page, even though it has saved those selections in the database, it doesn't not have them checked in the update page.
I've tried using pages generated by DataAssist and also from-scratch pages using WebAssist update and repeater.
Attaching the non-working file.
The manage relational table behavior uses the value you set for the master key to lookup what options should be preselected.
When tyhe page loads, you are passing in a URL variable named email_id as the master key.
you should use that variable in the manage relational table settings. instead, you are using the EmailID form element which does not have a value when the page loads.
to fix this:
Open the bindings panel and expand the URL biding collection. check to see if there is a biding named "email_id". If not, click the plus button to create a new binding, select URL, and name the binding email_id
On the server behaviors panel, double click the manager relational table behavior to edit it.
for the master key value, change from using the EmailID form element to using the email_id URL variable.
next edit the forms action so that the email_id URL variable still exists when the form is posted.
change:
action="messaging_email_update.inc.php"
action="messaging_email_update.inc.php?email_id=<?php echo $_GET['email_id']; ?>"
jake269602
That did it, thanks! Great support!
You're welcome.
