site was fine and 'suddenly' not
Thread begun 4/21/2014 7:39 am by Jamie | Last modified 4/21/2014 8:52 am by Jason Byrnes | 4752 views | 12 replies |
Jamie
Hi Jason
am not sure what has happened but for 'suddenly' (and not sure when as I was only advised of this yesterday by the client) a site that was workign absolutely fine and all content was being displayed as 'expected' is now not doing so.
On every page of this site, http://www.doghollow.co.uk, the main content is now being shown below the left hand column content and the content within the main content area looks like its being listed.
the site has been live, with no issues, for months now and cant find what is causing this issue at all. have been usign firebug to try and find the errant code but cant find it..... I woudl really appreciate your help when you get a chance please
Many thanks
Jamie
Using Fire Bug to analyze the page, the content div is inside the left column div.
the content div should not be nested inside the left column div.
I seem recall you had a similar problem in another site before that ended up being caused by one of the 3rd part script libraries you had added. I had noticed a similar nesting problem, but when you inspected the pages code, the content div was not nested, not sure.
But at any rate, the content div being nested in the left column div is the cause of the problem.
Jamie
actually it seems to be content related rather than css...
if i delete or hide the latest entry in the blog, this makes every page revert to how it should look... but as soon as the most recent blog is added something is buggering up the content area....
I have also tried leaving the latest blog post in and added a test one and it seems to be that one specific blog article that is causing it to happen...
Jamie
sorry posts seem to have crossed.... will look at the nested div as well but it is defintley one single blog post that is causing the issue.
if i leave it in and add a new blog post, everything goes back to normal... if I then re-create the offending blog post then it goes back to throwing things out...
edit... just looking at the nesting issue and the content div and left column areboth within the contentWrapper div but not nested within each other....
look for unbalanced tags in the blog post, most likely there is an extra closing or opening div tag, that would explain why the content div is being nested in the left panel
Jamie
OK, think I have narrowed it down to the " that the client has used in the post and have had problems with her keyboard in the past (and not got any resolution on it)
but why would that throw off all other pages as well rather than just the blog list and the article page itself?
No idea, I couldn't say without seeing it, and you seam to have removed it.
Jamie
OK have put it back to the way it was....
viewing the source code for the page, i see the following for the blogg:
<a href="blogarticle.php?ID=134-Confusing Alpha"> Confusing Alpha </a>
<div style="margin-top:10px;"></div>
Alpha meaning “denoting the dominant animal or human in a particular group” (Oxford English Dictionary)
<p... </div>
<div class="panelBase"></div>
</div>
it seams to not like the weird p tag:
<p... </div>
Jamie
this is the actual content code that is being stored in the database and shown in the editor in the backend:
<p>Alpha meaning “denoting the dominant animal or human in a particular group” (Oxford English Dictionary)</p>
<p>Dominant meaning “Having power or influence over others” (Oxford English Dictionary)</p>
I am sure its down to the "" that the clients keyboard kicks out but have never got to the bottom of why etc.
But why would this affect the WHOLE site rather than the pages that this content is being shown on (eg the blog list page and the article page itself?
edit actually I think i have answered it myself... its to do with the blog panel that is on each page... thats why its affecting every page on the site
