Some Ecommerce/product search advice needed
Thread begun 4/14/2014 1:06 pm by Jamie | Last modified 4/14/2014 2:40 pm by Jason Byrnes | 1407 views | 3 replies |
Jamie
Hey Jason
I am working on an Ecommerce site for a client that doesn't really conform to a category based structure as the products a incredibly varied/eclectic.
As such, I am thinking that the best/easiest way to deliver their requirements is to have a shopping page which lists products by most recent.
What I was thinking, to allow visitors some sort of search facility, is to give my client a <textarea> In each product entry where they add keywords associated with that particular product which will then display that product should any or any combination of keywords match that products.
Would I be right in saying that if I were to do it this way, would a partial 'hit' keyword return that product or would it need all keywords in that <textarea> to display that product?
Is there a better way to achieve this with the WA tools and my knowledge?
Cheers in advance
Jamie
Use Data Assist search for this to set up a keyword search criteria to search the keyword column
when you set up a keyword search in Data Assist search, by default it will set the keyword or to use a space, and the keyword and to use a comma. it will also set the start and end encapsulation to use quotes
this would me searching for:
foo bar
would create a search of the keyword column as:
WHERE keyword INCLUDES '%foo%' OR keyword INCLUDES '%bar%'
a search for:
foo, bar
WHERE keyword INCLUDES '%foo%' AND keyword INCLUDES '%bar%'
or a search for:
"foo bar"
WHERE keyword INCLUDES '%foo bar%'
Jamie
That's great. Thanks Jason
Should the client add the keywords to the <textarea> in a specific way (eg separated by a comma or space or something)?
Is using a <textarea> the 'best' way to do the data entry or is there a better way?
I assume your asking about inserting the keywords.
use a space to separate them.
a text area is fine.
