HTML 5 Form Field Names & Server Validation Panel in DataBridge
Thread begun 4/06/2014 3:15 pm by Paul | Last modified 4/07/2014 12:01 pm by Jason Byrnes | 2077 views | 3 replies |
PaulBeta Tester
I noticed that if a form field type is set type="tel" if one wanted to use HTML 5 form field convention for telephone, instead of type="text", the field(s) will not appear as selectable options in the WA Server Validations: Insert panel.
Is this intentional?
If not will there a fix or not?
Thanks, Paul
We use the Dreamweaver Bindings panel to populate the choices available for Server Validations.
this is an issue in the Dreamweaver bindings panel not recognizing HTML 5 element types.
For the time being, you will need to change the type to text, then change it back after using the server validation.
NOTE: in the curent version of Data Bridge, we use jquery for client validation. we use the HTML5Validate script which will allow for you to use standard elemnts types and emulate HTML 5 validation across browser platforms
PaulBeta Tester
Ok, makes sense.
Thanks for response
you're welcome.
