Sending an Email on a DataAssist Update or Insert Page
Thread began 8/20/2009 1:09 pm by karen.marley367377 | Last modified 8/21/2009 9:31 am by Jason Byrnes | 2141 views | 3 replies |
karen.marley367377
ASP Pages
Hi, I am applying UE to an Update Page, the Trigger being the update button,
I have UE throughout the site from the detail pages, but cannot seem to get it to work where there is an update or insert form.
Any tips?
most likely the Update or insert behavior is set to redirect to another page and the redirect occurs before the email is sent.
Double click the update or insert server behavior and cut the Redirect After value. Then go into the Universal Email and past it to the Redirect option on the general tab so that the page will only redirect after the email is sent.
karen.marley367377
Hi Jason, This is the error I receive...
Request object error 'ASP 0208 : 80004005'
line 137
Cannot use the generic Request collection after calling BinaryRead.
This is line 137-139
if (String(Request("MM_update")) == "WAATKUpdateForm") {
if (!MM_abortEdit) {
// execute the update
Cannot use generic Request collection
I have placed the Email SB after the UPDATE SB
This will occur when you use Digital File Pro on an ASP Page.
After uploading a file, the generic request collection cannot be used.
If the MM_update variable is a querystong variable, you can use:
if (String(Request.Querystring("MM_update")) == "WAATKUpdateForm") {
if it is a form variable you can use:
if (String(WA_DFP_UploadObj.Form("MM_update")) == "WAATKUpdateForm") {
But make sure that the code to upload the file is before this code.
