Uploading files on a update form.
Thread begun 3/07/2014 11:57 am by The Flying Fox | Last modified 6/04/2014 8:24 am by Jason Byrnes | 5080 views | 13 replies |
The Flying Fox
I have a update form which has a upload file field
this is for insurance documents to be uploaded
My file field has a hidden field.
file field name = insurance
hidden field = new_insurance
I have tried to follow the tutorial but this doesn't seem to work for me
I have the hidden field bound to the file column in my recordset.
in the upload file behavior, I have bound the Default file field to the hidden field.
when I run the update all I get in the database is the file extension
Can someone explain where I'm going wrong..
file attached
when you add file uplaod to your page, a new binding group is created:
WA Uploaded Files(Name of File Field)
this binding group contains a binding name d Server File Name.
you need to edit the update behavior to use the Server File binding for the file column.
The Flying Fox
Hi Jason,
I have tried this and still get the same results.
Andy
The Flying Fox
Sorted
Hi Jason,
I've found out where I was going wrong.
I omitted the [FileName] from the file field in the upload files bindings
ok, glad to hear it is working.
The Flying Fox
I am really pulling my hair our with uploading files.
I have followed all the rules and cannot work out why my files will not upload.
can you please take a look at the attached file and let me know where I am going wrong.
everything updates to the database but nothing is saved for the file name or as documents on the server
Thanks you.
the encoding type for the form uses application/x-www-form-urlencoded
enctype="application/x-www-form-urlencoded"
for file upload to work, the encoding type must be set to multipart/form-data
enctype="multipart/form-data"
The Flying Fox
thanks Jason not sure where that code came from..
you're welcome.
