Help with update page - not redirecting to page
Thread began 2/14/2014 11:16 am by iainmacdonald331081 | Last modified 2/14/2014 3:49 pm by Jason Byrnes | 448 views | 3 replies |
iainmacdonald331081
I have a page here with a form, which works, which is just a basic form which is inserting the contents into a database table and emailing the contents.
http://www.safariawards.com/nominate/
And I have pages like this one with details of a particular lodge, e.g.:
http://www.safariawards.com/botswana/africanhorseback/
I have been creating new page which combines the two, i.e. with the lodge details, and a nomination form.
If you go to this page:
http://www.safariawards.com/finalists/
Any links will take you to the new page, which is using a URL rewrite, e.g.:
http://www.safariawards.com/lodges/africanhorsebacksafaris/
Which is using a URL rewrite to display www.safariawards.com/lodges/index?GSG_URL=africanhorsebacksafaris
The form is working in that it is writing the contents to the database correctly, but it is drawing a blank when submitted rather than redirecting to the specified redirect page. The email isn't being sent either, but hopefully caused by the same issue.
I'm hoping its nothing too complicated, and just something I have missed, or have in the wrong order at the top of the page.
I have attached a copy of the page, and would be grateful if anyone could have a look to see if they can spot what's causing the issue.
Thank you.
in the email behavior, you are using a full address for the include location:
include("http://www.safariawards.com/webassist/email/waue_nominators_insert_1.php");
this cant be a full lURL, it has to be a relative path.
also, for the redirect, you use a full URL:
$WA_redirectURL = "http://www.safariawards.com/nomination_thanks/";
again, this needs to be a relative path.
iainmacdonald331081
Thanks Jason - the URL rewrite messed up the links to my CSS files. I saw that the solution for that was to use absolute paths, so had pre-emptively added a few more.
Glad it was a simple one!
glad to hear it is working.
