add multiple products to ecart (not utilising a checkbox)
Thread began 2/11/2014 10:24 pm by CraigR | Last modified 6/09/2014 10:04 am by Jason Byrnes | 553 views | 3 replies |
CraigRBeta Tester
I have created pages to add multiple items to a cart with a single click, (with ecart and dataassist search using the checkbox method), but would like to have the same functionality, except not using a checkbox, but relying on the post values of the quantity fields alone, so that the cart is populated if the qty field value is > 0.
Is this something that is easy to by adapting the dataassist search method, or do I need to hand code it ?
UPDATE
I guessed that if I don't bother with the 'Add to Cart' recordset, it could work, as items will not be added to the cart if their quantity is zero anyway.
Seems to work, and a lot easier then the checkbox method
Glad to hear you found a work around.
Nico
How to achieve the same but without using ecart
Hi.
I want to update a relational database but without the use of checkboxes. In my form I use an input value. So if the input value is not empty I want to update the relational table. Right now the table gets updated only if I have the checkbox checked. Thank you in advance
Not entirely sure i get what your trying to accomplish.
A relational table store IDs from 2 tables to create a many to many relationship.
A hidden element is used to store the parent ID,
the checkbox stores the child table ID
in the case of the manage relational table tutorial it is relating Items to genres.
The hidden element stores the ItemID, the checkboxes store the Genre ID.
When a checkbox is checked, it created a new record in the itemgenres table with the ItemID and the selected genre id.
you could add additional fields to the item genre table and use a text field to for that column, but if you where to replace the checkbox with a text field, you would need to input the genre ID manually.
