Moved To New Computer - Can't Get DB Connection
Thread begun 2/04/2014 7:49 am by David in Mississippi | Last modified 3/22/2014 6:39 pm by David in Mississippi | 6042 views | 14 replies |
My old computer, which worked beautifully with PowerCMS and other DB connections, crashed. Thanks to a good warranty, I now have a brand new computer and have installed all my old software on it (including Dreamweaver) and it's all working fine. I have reinstalled all my WebAssist tools and am trying to get them working.
For the first client I'm working on that uses PowerCMS, I set up the main server and tested it, got a good connection. I then duplicated that server as a testing server, tested it, and got a good connection.
When I opened up a client's page that has PowerCMS content, I get the message "Content Area Not Found." So I went to the Dreamweaver DATABASES tab and opened the PowerCMSConnection MySQL connection dialog, and clicked the TEST button. I got Error 404 file not found. I tried configuring both the main and testing servers with and without passive FTP, with and without IPV6 Transfer Mode, and with and without using the alternative FTP Move Method. All tests connected successfully to the server, and each resulted in the 404 error when trying to connect to the database.
HOWEVER, I know the client site works, because their on-site PowerCMS is working fine for them. I just can't get Dreamweaver to connect to the database. I know the PowerCMSConnection is good because it worked fine on the previous machine.
I'm using DW6 on Win7-64 with 16GB RAM.
What am I doing wrong? How can I get Dreamweaver to connect to the database? Thanks for any help you can offer.
the 404 error indicates a bad Web URL in the testing server settings.
make sure that the proper web address is entered in the WebURL setting.
if the FTP connection connects to a location outside of the site root, you may also need to add a root directory.
Thanks so much for your response. This is a very frustrating error. This kind of great support is a wonderful thing.
If this were not a proper web address, wouldn't I be unable to connect to the server when I click TEST on setting up the server? When I click TEST, I get the notification "Dreamweaver connected to your server successfully."
Also, everything I do is at public_html as site root, so my server root directory is set to /public_html. Is this wrong? (It still tests as connecting successfully.)
The testing server duplicates the main server, only the checkboxes Remote and Testing are different on the Site Setup panel.
Thanks again for your help.
testing the connection only tests the ability for dreamweaver to make an FTP connction.
it has nothing to do with the Web URL
When you test the database connection it places files on the site, then uses the web URL to access them
the 404 error means that the web URL is pointing to a different location then the FTP connection is connecting to.
make sure to use the proper URL for the Web URL in the testing server settings.
I'm not trying to be obtuse, really. But I'm confused.
The 404 error indicates the testing server does not map to http://www.sogomusicms.com/public_html/_mmServerScripts/MMHTTPDB.php.
I opened FileZilla and looked on the site and found that PHP file at that location.
Back in Dreamweaver, in the Basic Server configuration dialog for the testing server, the Web URL is http://www.sogomusicms.com/public_html/
It seems to me that the testing server IS mapped properly, and I can't figure out what I'm doing wrong. The text following the 404 message is no help. Your advice to "make sure to use the proper URL for the Web URL in the testing server settings" is undoubtedly accurate, but I thought I WAS using the proper URL.
It's probably something forehead-slapping simple, but I can't see it. I really appreciate your forbearance.
the web url should not contain the public_html/ folder. it should be just:
FONT SIZE="3 million" COLOR="Relieved" ... WHEW!! /FONT
!!!!!!!!!! Thank you!! !!!!!! (That solution worked!)
Now, why can't Dreamweaver give simple and unmistakable instructions!?!?
Again, thank you for your patience and sticking with me on this.
glad to hear you got it working.
Still Not Working
Yes, it's been more than a month since I got the Database Connection working - THANKS for your help on that!
But I am still getting "Content Area Not Found" on my DW web pages. (I got involved in a huge project meantime. That one's done.) I just opened up the databases panel and tested both database connections:PowerCMSConnection and RootConnect, and both said "Successfully connected to database."
However, the CMS content areas on the web pages still display "Content Area Not Found."
This was working fine on my old computer, and I haven't changed anything. Everything I said earlier in this thread about my computer and the website is still valid. I'm really scratching my head over this. Thanks so much for any help you can give.
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
