remove Universal Email page
Thread begun 1/29/2014 2:09 pm by thepair | Last modified 2/07/2014 2:03 pm by Jason Byrnes | 3034 views | 18 replies |
thepair
I have a working php page with Universal Email including an attachment BUT can not add the Progress Bar
I have uploaded the email folder this time.
So I would like to remove Universal Email BUT it is not listed under server behaviors
is it possible to have two Universal Emai on one site?
send a copy of the page and I can tell the code that needs to be deleted.
thepair
see below
this code:
<?php require_once("../../webassist/email/mail_php.php"); ?>
<?php require_once("../../webassist/email/mailformatting_php.php"); ?><?php
if (!isset($_SESSION))session_start();
if ((isset($_POST["sendEmail"]))) {
//WA Universal Email object="mail"
set_time_limit(0);
$EmailRef = "waue_index_2";
$BurstSize = 200;
$BurstTime = 1;
$WaitTime = 1;
$GoToPage = "thanks.php";
$RecipArray = array();
$StartBurst = time();
$LoopCount = 0;
$TotalEmails = 0;
$RecipIndex = 0;
// build up recipients array
$CurIndex = sizeof($RecipArray);
$RecipArray[$CurIndex] = array();
$RecipArray[$CurIndex ][] = "dave@seaportnet.com";
$TotalEmails += sizeof($RecipArray[$CurIndex]);
$RealWait = ($WaitTime<0.25)?0.25:($WaitTime+0.1);
$TimeTracker = Array();
$TotalBursts = floor($TotalEmails/$BurstSize);
$AfterBursts = $TotalEmails % $BurstSize;
$TimeRemaining = ($TotalBursts * $BurstTime) + ($AfterBursts*$RealWait);
if ($TimeRemaining < ($TotalEmails*$RealWait) ) {
$TimeRemaining = $TotalEmails*$RealWait;
$_SESSION[$EmailRef."_Total"] = $TotalEmails;
$_SESSION[$EmailRef."_Index"] = 0;
$_SESSION[$EmailRef."_Remaining"] = $TimeRemaining;
while ($RecipIndex < sizeof($RecipArray)) {
$EnteredValue = is_string($RecipArray[$RecipIndex][0]);
$CurIndex = 0;
while (($EnteredValue && $CurIndex < sizeof($RecipArray[$RecipIndex])) || (!$EnteredValue && $RecipArray[$RecipIndex][0])) {
$starttime = microtime_float();
if ($EnteredValue) {
$RecipientEmail = $RecipArray[$RecipIndex][$CurIndex];
} else {
$RecipientEmail = $RecipArray[$RecipIndex][0][$RecipArray[$RecipIndex][2]];
$EmailsRemaining = ($TotalEmails- $LoopCount);
$BurstsRemaining = ceil(($EmailsRemaining-$AfterBursts)/$BurstSize);
$IntoBurst = ($EmailsRemaining-$AfterBursts) % $BurstSize;
if ($AfterBursts<$EmailsRemaining) $IntoBurst = 0;
$TimeRemaining = ($BurstsRemaining * $BurstTime * 60) + ((($AfterBursts<$EmailsRemaining)?$AfterBursts:$EmailsRemaining)*$RealWait) - (($AfterBursts>$EmailsRemaining)?0:($IntoBurst*$RealWait));
if ($TimeRemaining < ($EmailsRemaining*$RealWait) ) {
$TimeRemaining = $EmailsRemaining*$RealWait;
$CurIndex ++;
$LoopCount ++;
session_commit();
session_start();
$_SESSION[$EmailRef."_Index"] = $LoopCount;
$_SESSION[$EmailRef."_Remaining"] = round($TimeRemaining);
session_commit();
wa_sleep($WaitTime);
include("../../webassist/email/waue_index_2.php");
$endtime = microtime_float();
$TimeTracker[] =$endtime - $starttime;
$RealWait = array_sum($TimeTracker)/sizeof($TimeTracker);
if ($LoopCount % $BurstSize == 0 && $CurIndex < sizeof($RecipArray[$RecipIndex])) {
$TimePassed = (time() - $StartBurst);
if ($TimePassed < ($BurstTime*60)) {
$WaitBurst = ($BurstTime*60) -$TimePassed;
wa_sleep($WaitBurst);
else {
$TimeRemaining = ($TotalEmails- $LoopCount)*$RealWait;
if (!$EnteredValue) {
$RecipArray[$RecipIndex][0] = mysql_fetch_assoc($RecipArray[$RecipIndex][1]);
$RecipIndex ++;
$_SESSION[$EmailRef."_Total"] = 0;
$_SESSION[$EmailRef."_Remaining"] = 0;
session_commit();
session_start();
if ($GoToPage!="") {
header("Location: ".$GoToPage);
is the universal email code.
thepair
I guess my title is misleading.
What I am trying to do is take a Universal Email page with an Attachment that works and add the Progress Bar.
every time I try something different it adds lines of code like
@import url("../../webassist/progress_bar/index_Universal_Email_2_Progress_4.css");
@import url("../../webassist/progress_bar/index_Universal_Email_2_Progress_5.css");
AND
<?php require_once("../../webassist/progress_bar/index_Universal_Email_2_Progress_4.php"); ?>
<?php require_once("../../webassist/progress_bar/index_Universal_Email_2_Progress_5.php"); ?>
The other page I was working on was not working because I did not upload the webassist folder before testing.
can I have more than one Universal Email per website?
sounds like you are adding the progress bar more than once.
each time you add the progress bar it will add the code for the index_Universal_Email_2_Progress_<int>.php and index_Universal_Email_2_Progress_<int>.css files
yes, you can have more than one UE per website, you can even have more than one UE per page.
thepair
I sent you my whole page, can you tell me what is wrong with it?
you don't give any indication of what is not working.
i have no way to know what is wrong with out any idea of what the problem is.
please provide steps to see the problem happen, a description of what should happen and a description of what is happening.
thepair
Hi Jason, thanks I will get back to you.
I am not sure what I did.
For some reason it started to work.
www.iobgd14.org/massEmail
thepair
I am testing Universal Email on my site and so have two folders each with a different Universal Email.
My question is why does Universal Email when it shows up in the Application->Server Behaviors as:
Universal Email 1
Universal Email 2 etc
in this case it showed up as Universal Email 2 in both folders
I have seen it as Universal Email 4 on another site
