nav behavior issues
Thread begun 8/19/2009 11:19 am by rick373876 | Last modified 9/02/2009 10:22 am by Jason Byrnes | 3216 views | 3 replies |
rick373876
nav behavior issues
I'm new to MenuWriter and an intermediate in Dreamweaver proficiency. I'm getting some strange behavior issues on my 2-level nav, specifically some of the 2nd level nav items fall off (disappear) in hover state and all 2nd level items pulsate in hover state. Template page can be seen at master3.html. Advice greatly appreciated.
Rick
You have created the problem by moving all of the menu css into the main.css file.
There are three files created by Menu writer.
menu.js - Contains javascript functions to combat some IE 6 and IE7 compatibility issues. Also contains functions for highlighting the top menu for the currant page.
menu.css - contains CSS For standards compliant browsers such as Fire Fox and Safari.
menu_ie.css - contains CSS for IE6 and under.
you have removed the menu.js file, removed the conditional comment that attaches the menu_ie.css file to IE6 and under and moved the css from both menu.css and menu_ie.css files to the main.css file.
by doing this, the css from the menu_ie.css is being used by all browsers, and so is the menu.css, this will cause conflicts in the css styles being applied.
You have also removed the javascript that initializes the menu.
rick373876
nav behavior issues
Thanks for your response and help. I've been out of town so just saw the reply.
At this point is this fixable or should I start over? if it is fixable, could you direct me to a source that will walk me through the protocol to repair?
Rick
To repair it, you would need to remove the menu css from the main.css file and replace the other code that was removed.
If you dont have a reference to the code that was removed, you are probably best of starting over.
