show if
Thread begun 1/24/2014 3:44 pm by Jamie | Last modified 1/27/2014 3:39 pm by Jason Byrnes | 4720 views | 13 replies |
Jamie
show if
hey Jason
I was wondering how one would go about using a show if based on 2 conditions (or if its even possible)
Basically, want this image
<img src="images/sponsors/<?php echo $row_PlatinumFooter['SponsorLogo']; ?>"  width="190" height="150" style="margin:46px 0 0 9px;">
to show based on these 2 conditions
if SponsorLive = 1 and SponsorCategoryID = 2
I can obviously use the show if in WA but that only gives me the one condition ... how would I modify it to include 2 and if that isnt the way to achieve it, what should I be doing?
Many thanks
you'll need to hand code the if statement for this:
<?php if($row_PlatinumFooter['SponsorLive'] == "1" && $row_PlatinumFooter['SponsorCategoryID'] == "2") { ?>
<?php } ?>
Jamie
Thanks Jason.
What I was looking to use that for was to be able to use one recordset and use the show if's to show the content for each relevant <div>
The below is onlyi returning the first <div>'s content but not the 2nd <div>
<div>
<?php do { ?>
<?php if($row_Sponsors['SponsorLive'] == "1" && $row_Sponsors['SponsorCategoryID'] == "1") { ?>
<div style="float:left; margin: 10px 0 10px 10px; background-color: #e9e9e9; border: 1px solid #ccc; padding: 5px;"> <a href="sponsor-detail.php?id=<?php echo $row_Sponsors['SponsorID']; ?>"><img src="images/sponsors/<?php echo $row_Sponsors['SponsorLogo']; ?>" width="260" height="137" border="0" /></a> </div>
<?php } ?>
<?php } while ($row_Sponsors = mysql_fetch_assoc($Sponsors)); ?>
<div style="clear:left; width: 630px; height: 20px;"></div>
</div>
<div style="clear:left; margin: 20px 0;">
<?php do { ?>
<?php if($row_Sponsors['SponsorLive'] == "1" && $row_Sponsors['SponsorCategoryID'] == "2") { ?>
<div style="float:left; margin: 10px 0 10px 10px; background-color: #e9e9e9; border: 1px solid #ccc; padding: 5px;"> <a href="sponsor-detail.php?id=<?php echo $row_Sponsors['SponsorID']; ?>"><img src="images/sponsors/<?php echo $row_Sponsors['SponsorLogo']; ?>" width="190" height="100" border="0" /></a> </div>
<?php } ?>
</div>
Remember when we talked last week and i showed you the Reset to first record behavior? you need to use that before the second div to reset the recordset.
you have a repeat region around the first recordset, and another around the second.
the second doesn't work, because the recordset is at the end, it needs to be ret to the first record using the behavior i showed you last week.
open the server behaviors panel, and click the plus button and select webAssist -> Dynamic Web Charts -> Reset Recordset.
Jamie
I thought it might have something to do with that! Thanks a million :D
you're welcome.
Jamie
Why would this not work Jason?
<?php if($row_SponsorsFooter['SponsorLive'] == "1" && $row_SponsorsFooter['SponsorCategoryID'] == "3" && $row_Sponsors['SponsorCategoryID'] == "4") { ?>
Jamie, need more details.
whenever you report a problem, the following information is needed:
What are the steps to reproduce the problem?
what is supposed to happen?
what is happening?
"it's not working" doesn't provide those details.
in this case, i would also need to also know what the values of these bindings is:
<?php echo $row_SponsorsFooter['SponsorLive']; ?>
<?php echo $row_SponsorsFooter['SponsorCategoryID']; ?>
<?php echo $row_Sponsors['SponsorCategoryID']; ?>
Jamie
OK sorry.. just thought it may be a quick fix.
So, this is part of a slideshow and there are 4 separate slideshows, one for platinum, one for gold, one for silver and one for bronze.
the plat, gold and bronze work fine and as expected( ie add images to the relevant slideshow based on if its live and a 'member' of the appropriate category (SponsorCategoryID)
The silver slideshow is slightly different in that the client has 2 sliver types. Silver Plus (SponsorCategoryID = 3) and Silver (SponsorCategoryID = 4) and therefore the silver slideshow needs to show images from both of those.
So to achieve that, I *thought* that this could be achieved by doing it this way;
<?php if($row_SponsorsFooter['SponsorLive'] == "1" && $row_SponsorsFooter['SponsorCategoryID'] == "3" && $row_SponsorsSponsorsFooter['SponsorCategoryID'] == "4") { ?>
The silver slideshow just doesnt display any of the images and you can see whats happening by going here http://clients.motley.co.uk/ITEAC/ and scrolling to the bottom of the page where you will see 4 hexagons ... the 2nd from right is the silver and silver plus and as you will see is blank
just before the if statement, echo the values:
<?php echo $row_SponsorsFooter['SponsorLive'] ."|". $row_SponsorsFooter['SponsorCategoryID'] ."|". $row_SponsorsSponsorsFooter['SponsorCategoryID']; ?>
what does that return?
my bet is that it wont return the values you expect, not that you are using 2 different recordsets, this probably wont give the desired results unless the SponsorsSponsorsFooter is nested in the first one.
http://www.webassist.com/tutorials/Display-nested-recordsets
