Access denied for user 'kazinikazi'@'184.168.193.116' (using password: YES) in
Thread begun 12/11/2013 9:47 pm by info290144 | Last modified 6/06/2018 9:14 am by Ray Borduin | 4239 views | 7 replies |
info290144
New Server
I have moved my old website to a new server on godaddy servers. When I go to the website, I get a blank page; http://bestdementiavideosandbooks.com OR http://www.bestdementiavideosandbooks.com/admin/
Please help.
The error means that the MySQL server Is not accepting the User Name and password that are entered in the Connections/PowerStoreConnection.php file.
you should check with you host for the correct Details for connecting to the database and edit the Connections/PowerStoreConnection.php with that information.
info290144
Thanks for the reply. Somehow database password was changed and not on the connection file.
Glad to hear you found the problem.
info290144
Have you guys considered making your products for joolma extensions? I think it would be great for you guys to get a slice of the joomla market.
i will forward the suggestion, you can also post feature suggestions to our suggestion page:
http://www.webassist.com/community/feedback/dashboard.php
timsemailaddress275998
Same issue
I'm having the exact same issue. I used the install script to install the tables in my DB, but now I'm getting the mysql connect error. I did not change the credentials, but this will not connect. I've changed the DB password manually and updated the new password in the Connections file without luck.
Is there anything else I can try?
