Problems sending to CC and BCC from script
Thread begun 12/09/2013 11:35 am by J7HNW | Last modified 12/13/2013 9:00 am by Jason Byrnes | 6205 views | 21 replies |
J7HNW
I am moving all sites to a new server running Plesk 11.5. On the old server all forms worked fine
I cannot get the forms created in UEM to send a CC or BCC back to the hosting e mail address
which sends the form ( So it will send to the client who enters their data in the form - but where
the BCC is back to my e mail address this will not come through
The Tech Support on the server say..... this is a problem with our script
Please can you advise as I have 25 more sites to move all with forms created in UEM
Hi John
I've spent some time looking into the email issues from web forms: We have set both servers to allow relay from each other.
Check out these simple PHP email pages:
C:\Inetpub\vhosts\qrcodesforyou.co.uk\httpdocs\mail.php
C:\Inetpub\vhosts\qrcodesforyou.co.uk\httpdocs\mail2.php
I can send emails to and from iinfo@qrcodesforyou.co.uk and sales@webjectives.co.uk and to ernestltd@yahoo.co.uk and the emails are arriving. This suggests the code you have sending the emails isn't compatible with this newer plesk server. I dont have time to debug the code you have in your forms sending the email obviously to find out the exact problem. I suggest you try to do this yourself
Look at the smtp logs:
C:\Program Files (x86)\Parallels\Plesk\Mail Servers\Mail Enable\Logging\SMTP\GET THE LATEST ONE
From my email script:
2013-12-09 18:42:41 127.0.0.1 SMTP-IN 127.0.0.1 1008 HELO HELO+webjectives 250+Requested+mail+action+okay,+completed WEBJECTIVES 43 18
2013-12-09 18:42:41 127.0.0.1 SMTP-IN 127.0.0.1 1008 MAIL MAIL+FROM:<sales@webjectives.co.uk> 250+Requested+mail+action+okay,+completed WEBJECTIVES 43 37
2013-12-09 18:42:41 127.0.0.1 SMTP-IN 127.0.0.1 1008 RCPT RCPT+TO:<ernestltd@yahoo.co.uk> 250+Requested+mail+action+okay,+completed WEBJECTIVES 43 33
2013-12-09 18:42:41 127.0.0.1 SMTP-IN 127.0.0.1 1008 DATA DATA 354+Start+mail+input;+end+with+<CRLF>.<CRLF> WEBJECTIVES 46 6
2013-12-09 18:42:41 127.0.0.1 SMTP-IN 127.0.0.1 1008 DATA DATA 354+Start+mail+input;+end+with+<CRLF>.<CRLF> WEBJECTIVES 43 135
2013-12-09 18:42:41 127.0.0.1 SMTP-IN 127.0.0.1 1008 QUIT QUIT 221+Service+closing+transmission+channel WEBJECTIVES 42 6
2013-12-09 18:42:43 188.125.69.79 SMTP-OU 1120 CONN 0 63
2013-12-09 18:42:43 188.125.69.79 SMTP-OU 1120 EHLO 220+mta1188.mail.ir2.yahoo.com+ESMTP+YSmtpProxy+service+ready 23 81
2013-12-09 18:42:43 188.125.69.79 SMTP-OU 1120 MAIL EHLO+WEBJECTIVES.home 250-mta1188.mail.ir2.yahoo.com 46 41
2013-12-09 18:42:43 188.125.69.79 SMTP-OU 1120 RCPT MAIL+FROM:<sales@webjectives.co.uk>+SIZE=295 250+sender+<sales@webjectives.co.uk>+ok 33 42
2013-12-09 18:42:43 188.125.69.79 SMTP-OU 1120 DATA RCPT+TO:<ernestltd@yahoo.co.uk> 250+recipient+<ernestltd@yahoo.co.uk>+ok 6 14
2013-12-09 18:42:44 188.125.69.79 SMTP-OU 1120 DATE DATA 354+go+ahead 306 15
2013-12-09 18:42:44 188.125.69.79 SMTP-OU 1120 QUIT 250+ok+dirdel 6 32
From your email script (doesnt work)
2013-12-09 18:20:42 188.65.33.70 SMTP-IN 188.65.33.70 1088 HELO HELO+webjectives 250+Requested+mail+action+okay,+completed WEBJECTIVES 43 18
2013-12-09 18:20:42 188.65.33.70 SMTP-IN 188.65.33.70 1088 MAIL MAIL+FROM:<sales@webjectives.co.uk> 250+Requested+mail+action+okay,+completed WEBJECTIVES 43 37
2013-12-09 18:20:42 188.65.33.70 SMTP-IN 188.65.33.70 1088 RCPT RCPT+TO:<ernestltd@yahoo.co.uk> 503+This+mail+server+requires+authentication+when+attempting+to+send+to+a+non-local+e-mail+address.+Please+check+your+mail+client+settings+or+contact+your+administrator+to+verify+that+the+domain+or+address+is+defined+for+this+server. WEBJECTIVES 235 33
2013-12-09 18:20:42 188.65.33.70 SMTP-IN 188.65.33.70 1088 QUIT QUIT 221+Service+closing+transmission+channel WEBJECTIVES 42 6
Best regards,
Jon Lucas
the output is saying the server requires authentication.
In universal email, In the from settings, select the option to include the from address as an extra perameter.
you may also need to set the sendmail_from perimeter by adding the following code at line 1:
<?php ini_set('sendmail_from', 'example@YourDomain.com'); ?>
J7HNW
Thanks Jason
see PM
J7HNW
Hi Jason
see PM
J7HNW
Still no good
J7HNW
Details below
see PM
