Visual C++ runtime library...
Thread begun 8/18/2009 4:03 am by gofetsch242800 | Last modified 8/20/2009 12:14 pm by Jason Byrnes | 3222 views | 3 replies |
gofetsch242800
I get this fatal error when trying to run WA Data Assist wizard. It has been OK in days past, but last several efforts result in this, which requires restarting Dreamweaver:
Runtime error!
Program: C...
R6025
- pure virtual function call
It is perplexing. I have recreated my db in phpmyadmin. Dreamweaver's links set relative to document.
Many thanks
This error usually happens if the "Create links Relative To" option on the Local Info tab of your site definition is set to "Site"
Edit your Site definition in Dreamweaver and Change the "Create Links Relative To" option on the Local Info tab to "Document" before running the DataAssist wizard.
gofetsch242800
that's not it...
Thanks for the reply, but I had seen this advice in the past and noted in my OP that 'links relative to' was set to 'document.'
I did work it out, sort of. After a number of efforts failed, I finally another user on my PC, reloaded the DA extension there, and now have managed to complete the wizard again. If only I could recall how I had fixed this before in my detail page:
<<You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'PRIMARY = 1 OR ( -1= 1 AND PRIMARY= 2)' at line 1>>
It sounds as though you have a column in your database named PRIMARY. this is a reserved word in MySQL and should be avoided as a column name. A full list of reserved words can be found here:
reserved-words.html
