Fatal Error
Thread begun 11/10/2013 2:43 am by savvy1297305 | Last modified 11/11/2013 1:44 pm by Jason Byrnes | 5610 views | 7 replies |
savvy1297305
Fatal Error
I have a form on one of my sites built with form builder and has been live and functioning correctly for well over 12 months, however just today the page the form is on wont display. A fatal error message comes up instead which mentions issues with line 9 but previously it was giving similar details about line 3 and 4.
Here is a link to the page and the error http://www.guidedpath.com.au/registration.php
Here is the code from the first few lines of the code concerned
<?php require_once("webassist/form_validations/wavt_scripts_php.php"); ?>
<?php require_once("webassist/form_validations/wavt_validatedform_php.php"); ?>
<?php require_once( "webassist/security_assist/helper_php.php" ); ?>
<?php require_once('Connections/guided_path.php'); ?>
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$WAFV_Redirect = "registration.php";
$_SESSION['WAVT_registration_145_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateLE($_SESSION['captcha_Security_Code_1'] . "",((isset($_POST["Security_Code_1"]))?$_POST["Security_Code_1"]:"") . "",true,3);
Any help would be appreciated
Regards
Bruce
the error is saying that the user name used for connecting to the mysql database server in the Connections/guided_path.php is not being accepted.
The connection details in the Connections/guided_path.php file need to be corrected.
savvy1297305
Thanks Jason I can see that however to my limited knowledge on php etc I have never set this. Is it something form builder does automatically and if so how do I re set it
No, it is not something form builder would have set automaticly, you would have needed to create a database conenction prior to running form builder.
in Dreamweaver go to Window -> Databases. in the databases tab, double click the guided_path database connection to edit it and change the settings used.
if you are not sure what settings should be used, contact the host.
savvy1297305
Have done as you suggested - tested the connection in DW and it tests ok. Is this an issue with the host then?
In DW, do you have the site definition set to connect to the local server for testing?
when you upload to the remote server, you need to update the connection for the remote MySQL Server, you wont be able to use the local MySQL Server on the remote server.
savvy1297305
Now you are getting into unchartered waters for me so if I could go back a step and say that this page has worked fine for over one year now with no changes and it just stopped working and displaying that message.
I have made no changes and in any of the other forms I have set up using Form Builder there is no problem
regardless of whether the page was working before or not, the error is saying that the connection details for connecting to the mySQL Server are not correct.
if you think they are correct, you should contact the host to determine why the mySQL Server is not accepting them.
