Confirm page before ecart
Thread begun 11/07/2013 6:44 am by ori382079 | Last modified 11/07/2013 1:36 pm by Jason Byrnes | 1476 views | 3 replies |
ori382079
Please advise me of steps to take in doing this task. I have a form which will insert the data entries into a database table, but before inserting the data, I want the user to check and confirm the data entered. Once the user is OK with the data, submits the data then the ecart should come up .
Store the initial data into Session variables:
on the server behaviors panel, click the plus button and select eCart -> General -> Set Session Variable
use the session variables to display it on the confirm page and when confirm trigger the add to cart button behavior:
server behaviors panel, click the plus button and select eCart -> add to cart -> add to cart
on the bindings panel, use the session bindings to add the item info to the cart.
ori382079
Thanks Jason, How do I use the session variables to display in the confirm page? Sorry I'm a bit confused here!
use the bindings from the bindings panel.
