Creating Registration Page
Thread begun 10/27/2013 12:17 pm by balexander389215 | Last modified 11/14/2013 8:31 am by balexander389215 | 8342 views | 19 replies |
balexander389215
I used SA Wizard to create the login/registration pages. My problem is that the information I want to include in my Registration page is contained in two tables in the DB. I was unable to figure out how to pull the information from two pages. Is there a way to make this happen or perhaps a way to edit the page to add these fields after the fact?
please provide more details on the table structure of each table and the use case for the second table.
balexander389215
I'm trying to set up login and registration pages with a 'my account' section, very much like what you have on your site. I have an eCommerce db which divides the registration and address tables into two, but for the pages I want to createI need information from both tables. The registration pages I'm creating are not for the store but another part of the site, however I want to use these tables to avoid having a dual login.
so in the address book table, it looks like you have the userid to be used as the foreign key to create the relation to the customers table
your registration page needs to have 2 data assist insert record behavior. The foist one will store data to the customers table and save the id to a session variable.
the second one will store data to the address book table. For the userid column use the session that is created by the first insert behavior
balexander389215
Yes but how do I do it, that's the question. The one tutorial I can find only shows how to use the wizard to create the initial pages. Is there another tutorial hidden somewhere on how to add additional record sets?
there is no tutorial for this, it is not a normal use case.
To do this, you need to create the functionality manually using Dreamweaver and the Server Behaviors of Security Assist And Data Assist.
Create the form with the needed form elements.
add the insert record behavior to save data to the customers table (on the server behaviors panel click the plus button and select WebAssist -> Data Assist -> Insert -> Insert Single record) , in the first screen make note of the session name that the ID will be stored to.
On the bindings tab, select each column, click the lightning bolt for value and select the corresponding form element.
Add the second insert behavior to save data to the address book table.
on the bindings tab, select each column, click the lightning bolt for value and select the corresponding form element.
For the user ID column use the session that is created in the first insert behavior.
balexander389215
Thank you for your help Jason. Okay I followed your instructions and got to the insert single record screen. The first thing to set is Trigger. I have no idea what is supposed to go here but clicking on the lightning bolt I have several options. I went to the record set dropdown and chose address as it was the address I wanted to insert. (However I'm sure that's wrong. It doesn't look at all like the Trigger inserted by the wizard.)
Then there's the session name you told me to take note of. That was blank. The wizard uses a session id name of SecurityAssist_id so I used that name. Is there any special name that is supposed to go in here?
On the bindings screen I simply went to the bolt and clicked again on address.
Okaying this added the new record set into the head of the page but nothing into the body. How do I get the field into the body? Is this something I have to do manually? Are there instructions to create this and link it to the record set?
Finally how do I get rid of the security question component on the registration page. I just want the captcha but saw no point where I could configure this in the wizard.
see pm
balexander389215
See pm
See PM
