Is there a way to delete an image that is associated with a record without deleting all the images from image folder?
Thread begun 10/24/2013 9:12 am by danny405167 | Last modified 10/24/2013 10:01 am by danny405167 | 2828 views | 4 replies |
danny405167
What I want to do is to when ever I need to delete a record, the image that is associated with the record needs to be deleted as well. All the treads that people have posted are for deleting multiple images. The following code below deletes all of images which is not what I want.
<?php if(isset($_POST['deleteProduct'])) { ?>
<?php do { ?>
$WA_DeleteFileResult1 = false;
if(isset($_POST["deleteProduct"]) || isset($_POST["deleteProduct_x"])){
$WA_DeleteFileResult1 = WA_FileAssist_DeleteFile("../../store/images/", "".$row_rsInventory['ProductImage'] ."");
<?php } while ($row_rsInventory = mysql_fetch_assoc($rsInventory)); ?>
<?php } ?>
add a hidden form element to the delete form that stores the image name for the record being deleted. In the delete behavior, bind the file name to the hidden element
danny405167
"In the delete behavior", are you referring to the DataAssist Delete single Record or to the File Manipulation Delete File?
My hidden form field below is what I bind to delete a record
<input type="hidden" name="WADADeleteRecordID" id="WADADeleteRecordID" value="<?php echo $row_rsInventory['ProductID']; ?>" />
Then I added
<input name="deleteImage" type="hidden" id="deleteImage" value="<?php echo $row_rsInventory['ProductImage']; ?>">
and set the trigger for the delete file with the hidden form field
<?php if(isset($_POST['deleteImage'])) { ?>
<?php do { ?>
if((((isset($_POST["deleteImage"]))?$_POST["deleteImage"]:"") != "")){
<?php } ?>
but still is deleting all of my images
I am referring to the delete file behavior.
in the delete file behavior, bind the file name to the hidden element.
danny405167
Thanks. It is working now.
