Help with double opt tutorial
Thread begun 10/02/2013 10:20 am by danny405167 | Last modified 10/09/2013 12:48 pm by danny405167 | 7213 views | 17 replies |
danny405167
I am having problem with making the "Your email hasn't been verified. Please click here and we will email you a new link" appear after the user has changed the email address. The UserEmail gets updated with the new email and UserEmailVerified gets updated from 1 to 0 but the link does not appear. The only time that I can make the link appear is when I call the logout.php page to kill the session. Is there a step missing in the tutorial where after changing the email address(in the userupdate.php) the session should be killed so that the user gets to see and click on the link to get the email verified?
I will post the link and your info to logging into the site
danny405167
Originally Said By: danny405167
Yes, there should be another step on the userupdate page to add another set session value behavior.
For the trigger, click the lightning bolt and select the send URL variable.
Set the session name to:
emailVerified
and the value to 0.
danny405167
I added the session value and still the link does not appear when the email is changed. I have to log out in order for it to appear. The show region is set up as NOT VERIFIED USER
<?php if(!WA_Auth_RulePasses("Verified User")){ // Begin Show Region ?>
Your email hasn't been verified. Please click here and we will <a href="userupdate.php?send=true">email you a new link</a>.
<?php } // End Show Region ?>
danny405167
danny405167
danny405167
I sent you the info you requested
see pm
danny405167
Thanks, It worked.
I did the same for the user-confirm.php page. I have a test page named access.php with User Verified restriction. Every time I clicked on the
"Thank you for verifying your email address. You may now access restricted content.", the link would fail and redirect to the userupdate.php page.
I moved the code to be after the recordset, but before the update
if(!($totalRows_rsVerify == 0)) {
$_SESSION["UserEmailVerified"] = "1";
