Page set to use static Theme It opens blank in testing
Thread begun 9/24/2013 8:14 am by evansg7124312885 | Last modified 11/25/2013 9:10 am by Jason Byrnes | 6756 views | 18 replies |
evansg7124312885
User Logout page was initially built by Security Assist wizard. I applied template, then applied static theme it and went to test (this is all that was done to the page); page came up plain white, no errors, but no content. Tried detaching template, reattaching, and applying theme it, no change. Built a new logout page (not a lot of time wasted here); same processes, same result.
What is weird about this one is that there are a lot of other pages within the site using theme it with no issues, it only occurs on this page.
Any input is welcome, thank you.
Using DW 5.5, checked WA versions, Mac OSX 10.8.
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
evansg7124312885
Text from page error
Added line, tested, here is what I got:
Warning: require(sitesculptor_template_fw_theme.dwt.php) [function.require]: failed to open stream: No such file or directory in /Applications/MAMP/htdocs/ipad4/userlogout.php on line 32
Fatal error: require() [function.require]: Failed opening required 'sitesculptor_template_fw_theme.dwt.php' (include_path='.:/Applications/MAMP/bin/php5.3/lib/php') in /Applications/MAMP/htdocs/ipad4/userlogout.php on line 32
The path looks correct to userlogout.php file, I did test a couple other files using framework, they are still working as expected.
Thanks,
Gary E
That error means that the theme file is not on the server.
upload the entire contents of the Templates folder including the Templates/Themes folder to the server.
evansg7124312885
My development and test server are the same thing
I know, they should be separated, but they are not. My test server is in the local host environment which is also where I develop pages and WA files are stored until published to remote. Is it possible that this file is looking for something different than the other files that do work? I did use File-New-from template to create this one after the WA generated file had this problem. I have attached the log in page which I tested right before second reply and it worked OK.
I dont follow. see pm
evansg7124312885
Test server and development environment are the same thing
All files are stored and developed in the testing server folder, there would be no where else to put them for testing.
see PM
evansg7124312885
See PM
See PM
see PM
