isn't my insert record behaviour trigger working?
Thread began 9/09/2013 10:00 am by bentulk | Last modified 9/09/2013 12:46 pm by bentulk | 860 views | 2 replies |
bentulk
I am trying to stuff site-search terms into a database.
I have built search and results pages successfully.
I have applied an insert record behaviour, which uses the session variable created by the keyword search, and stuffs this in database table.
The problem I'm having is with the trigger.
The only trigger I can get to work is the 'before page load'. I can't use this, because, it stuffs the keyword in every time a user goes to and from detail page.
I tried to apply the 'on Search button pressed' trigger (made sense), but when i try this, no record is inserted into the database.
(when i change trigger back to 'before page load' it works fine again.)
Can you help please?
I have attached the code for my results page here.
Thanks,
Ben
webassistSearchInsert.txt
on the bindings panel, click the plus button and select URL variable, name the new binding "Search" (without quotes).
for the trigger, click the lightning bolt icon and select the Search URL variable.
bentulk
Jason,
Once again, works perfectly. Thank you very much.
Ben
