Dont find my custom stylesheet
Thread begun 8/29/2013 11:16 am by Jonas | Last modified 8/29/2013 1:43 pm by Jonas | 1751 views | 4 replies |
Jonas
I do not know what I'm doing wrong but something must be. Every time I attempt to attach a style-scheet to cms system so it will not work.
I've managed it before. But now it was a while ago. And I remember that it was not entirely easy last time either.
I do as it says in the manual every time.
1. Choosing 'Edit' in the HTML editor from 'content-insert' page.
2. Enter 'Styling' menu and add a custom css page.
3. Pressing the 'Modify the options ...'
4. Press 'Import'.
But the only thing I can select is the Classes: current, hover, indentation.
It does not seem to find my stylesheet.
is this using the current Power CMS Builder from Design Extender 1.1.5?
if so, you need to manually edit the webassist/ckeditor/styles_list/stylelist1.js file to add your custom styles.
Using HTML Editor to edit the CKEditor instance in Power CMS Builder from DE 1.1.5 will break it.
Jonas
I discovered that I have DesignExtender 1.1.3 installed. I'll have to install the new one. But I'll wait a bit with this, so that this site works first.
Is there no easier way and more logical to link the custom stylesheet in CMS tool.
The easiet way is to use version 1.1.5 and edit the webassist/ckeditor/styles_list/stylelist1.js file to add your custom styles.
Jonas
Ok, I see. Thanks!
