Three websites connect to DB, no others will
Thread begun 8/07/2013 8:31 am by David in Mississippi | Last modified 8/07/2013 2:58 pm by Ray Borduin | 2441 views | 4 replies |
Please let me apologize in advance for this question being so long, but I want to explain all I have done so you don't have to tell me to try it again.
Also, in advance, I want to thank Jason and Ray for being so patient and forebearing with all the questions they deal with. Part of my advance information is to say I have browsed nearly 100 forum help topics and have not found an answer to my question; but I have noted how patiently Jason particularly deals with all the questions. So thanks for that.
IN A NUTSHELL: I cannot get Dreamweaver (CS6) to connect to more websites' databases - I keep getting the 404 error.
You probably know what I mean, but just in case, it's the one that says 'The testing server specified for this site does not map to the http://(site URL)/public_html/mmServerScripts/MMHTTPDB.php" URL. Verify that the URL prefix maps to the root of the site.' - I checked, and as near as I can tell, it does.
DETAILS: I have three websites I have already built in DW that connect to databases just fine, and they all work from the same HostGator shared host.
I purchased WebAssist - the full nearly $1,000 bundle - about a month ago, and installed CMS on one website (www.sogomusicms.com) and it works fine and the customer is tickled with it. (I do have a question about allowing the customer to edit photos in the CMS, but that's a topic for another thread.)
When I try to get DW to connect to a database on any NEW site I create, I keep getting that frustrating 404 error. Here's what I've done in an attempt to solve the problem (multiple checks and double-checks for each):
- I checked for the MMHTTPDB.php and mysql.php files in the _mmServerScripts folder, and they are there. I compared these files to the same files on the websites whose connections operate properly, and they are identical.
- I checked the remote and testing servers setup in DW, and they are set up exactly the same as the servers in the websites whose connections operate properly, and the [TEST] button yields the "Dreamweaver connected to the web server successfully" message.
- I have tried both the assigned user/password and the site root username/password combinations with no luck. (One of the sites that works properly will not work with the assigned user/password but it will work with the site root username password. Curious.)
I am developing on the live testing server, not using WAMP or XAMPP. I have XAMPP installed, and have attempted to develop using it, but I encountered the same error, so I went back to my preferred method of development, on the live server.
Finally, in frustration, I hand-coded a database connection in PHP on a test page of one of my sites. The hand coded connection works perfectly, connecting to the server and the database, and listing the tables in the database. Yet when I copied and pasted the host, username, password, and database name from the hand-coded connection to the DW-generated Connection01.php file, I still get the 404 error.
As you can imagine, my frustration levels are reaching new highs.
I've been chasing this problem for nearly a month now. No one at Adobe or on any of their forums is any help.
If I cannot make a DW database connection, then I cannot use any of these (expensive!) WebAssist tools, so I'm hoping someone here can help.
I have a new client who wants me to build a shopping cart website, so I'm desperate to get these connections to work.
Thanks in advance for any help you can offer.
David
NEW INFORMATION as of 1:30 pm, same day as original post.
I figured a 404 error meas Apache is trying to serve up a requested page, but it cannot find the page.
So I went to www.bigbandchartsgroup.com/mmServerScripts, one of my sites that works fine with DW, and saw a listing of the files there, which included the MMHTTPDB.php file. Fine, that's as it should be.
I then went to www.mcsb.us/mmServerScripts, one of my sites that will NOT allow DW to get a connection, and saw a listing of the files there. Guess what... the MMHTTPDB.php file is there as well. So obviously the file is present. WHY am I getting this frustrating 404 error?
(Pardon me while I gnash my teeth.)
This is probably just an issue with your Dreamweaver site definition... if you post your phone number in the private message area in a reply to this post I'll give you a call and help you figure out what you have done wrong.
Thanks! Posting now.
We looked into this and it was a bad url setting for the testing server in the Dreamweaver site definition... fixing the url caused the connection to work.
Outstanding Support - THANKS!
Let me go into a bit more detail here, since the solution may help someone else with the same problem.
In DW, when setting up your servers, using a LINUX host (I'm using HostGator), the FTP address is your site URL, the "Web URL" is your site URL prefixed by http:// -- there should be nothing after the top-level domain extension (.com or .org or .us or whatever).
The root directory should be public_html
I had all that just fine on the remote server. However, on my testing server, in response to the 404 error message that said the testing server should map to (URL)/public_html/(etc.), I had added /public_html to the Web URL field, and it should not have been there.
As is usually the case, this was something small that I overlooked, and I'm hugely grateful to Ray for taking the time to point this out to me.
This is the kind of support that (a) I hate to ask for because it takes up people's valuable time - but I was down to grasping at any help I could get; but also (b) will keep me, and many others, I should think, a loyal customer of Web Assist.
Thanks again for the help.
